1988 TRX 350...smoking
Old Aug 7, 2008 | 05:51 PM
TheRiverHawk's Avatar
Default 1988 TRX 350...smoking
Hey guys...
The strangest thing happened recently....
I changed the oil as I do at least once a year. For the first time, I decided to go with a K&N oil filter this past time. I went riding a couple of days later and, for the first time ever, the ATV is putting out a decent amount of smoke from the exhaust. Could it be related to the oil change and/or the new brand of oil filter? It's smoked some each time I've ridden it since. I do know that it's older, but it has been very well maintained. If you weren't an expert on ATV's you'd never guess it was 20 years old.
Just curious if anyone thinks I've blown a seal/gasket and it's related to the oil change.
How difficult would it be for a weekend warrior kind of guy to rebuild it himself?
Blessings to you all!
Jeff
The River Hawk
Old Aug 8, 2008 | 12:29 AM
ride_2die1's Avatar
my guess is that either something wrong with a piston or u broke a seal thats what i did with mine. You might want to talk to a real mechanic and see what type of oil u should use!
Old Aug 8, 2008 | 04:24 PM
Williebee's Avatar
It could be excessive carbon buildup in the combustion chamber causing the rings to stick , try mixing your fuel with Sea Foam and ride it untill you have to refill the fuel tank again ; i had to do this to my 88' GMC S1500 Jimmy MPV that had started smoking after it warmed up !
It's worth a try the Sea Foam did the trick on my Jimmy , you can get Sea Foam at any Auto Parts Store ; and at most WalMart Super Centers there's complete mixing instructions on the can !
Good luck , i hope this works for you ; and welcome to the forums !.....
Valder
Nov 28, 2020 07:38 AM
big_g_squared
Jun 28, 2015 04:17 PM
YZBlaster250
Jun 26, 2001 06:57 PM
BIRDofPREY
Mar 6, 2001 11:56 PM
jts
Jan 18, 2001 07:33 PM
