still smoking after
Old Aug 31, 2008 | 12:20 PM
hondaaaa350's Avatar
Default still smoking after
I have replaced rings,valve seals on TRX 350 fe put it all back together no blue smoke but after running for a few mins it started to smoke again but not blue this time. its kinda looks a black this time, did I do something wrong? maybe adjusted valves wrong I don't know.
I had cylinder de-glazed, and had honda dealer grind valve seats and put new seals on
Thanks
Old Aug 31, 2008 | 03:55 PM
Gimpster's Avatar
Intake valves may be a little snug. Carb float hanging up, choke valve not closing all the way, primer diaphram is shot
Just a few things to check into
----- Gimpster -----
Old Sep 1, 2008 | 01:55 AM
I took it for a ride today for about 2 hours and seems to be ok now smoke went away after about 10-15 mins.
Thanks for reply.
Old Sep 1, 2008 | 01:17 PM
270quadsportguy's Avatar
oil buildup in muffler
Old Sep 1, 2008 | 05:21 PM
Gimpster's Avatar
Black smoke though ? hmmmm
I think the fuel issue fixed itself
----- Gimp -----
Old Sep 1, 2008 | 11:12 PM
Thanks for info, it started again today a little bit and I check the choke like you said and the cable wasn't all the way in I played around with it for a min then it was good again ,no smoke.
Thanks for your help
Old Nov 3, 2008 | 10:16 AM
justin_hogan's Avatar
What year of 350? I have a 87 trx350 that smokes all the time. How much of a job was the rebuild - How much money did you have in the rebuild?
Old Nov 3, 2008 | 12:17 PM
It is a 2003 trx 350, and it was very easy to do I just bought a service manual for that bike and it tells you step by step. The service manual explains everything very well. I spent $165.00 on parts and cost me another $170.00 to regrind valve seats and have cylinder honed
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
