Flooded my 2008 Manual Foreman
Old Sep 14, 2008 | 06:11 PM
baseballjeff's Avatar
Default Flooded my 2008 Manual Foreman
Hey Everyone,
A little help here would be GREATLY appreciated. Should I take it into the shop? Or, is it easy enough to fix myself.
Thank you everyone in advance,
Jeff
Old Sep 14, 2008 | 08:06 PM
JeffinTD's Avatar
Any idea if you just got clean water in there, or if there's dirt and grit in the engine?
If it's just water you might get by with draining the engine and changing the filter, flushing with some light oil, refill, run briefly, drain... change oil again, run for a while... repeat until oil stays clean looking...
If grit and sand got in there, there probably isn't any way to get everything out short of taking the engine completely apart. If that's the case, I'd go ahead and replace the oil cooler, too, since there's no real way to tell if whatever you did to clean it got it clean- or if grit is in there waiting to come loose once hot oil hits it.
Old Sep 14, 2008 | 08:18 PM
The water was sandy silt like. I've heard that if I plug the intake with my hand, or something, it creates a vacuum and it'll blow everything bad out and start up after a little bit.
Thank you. Does this happen a lot to others? I am getting nervous.
Old Sep 15, 2008 | 06:51 PM
JeffinTD's Avatar
If there's sandy silt like stuff in the motor, I think you'd be better off taking it apart... but that's just my .02.
I've read stories of people who got mud and silt in the motor, tried to flush it out and ran the motor, only to ruin lots of expensive parts (piston, rings, main bearings, oil pump...)
Maybe one of the pros will respond with more expert advice...
Old Sep 16, 2008 | 12:14 AM
JeffinTD,
Thank you!
I ended up just playing it safe and taking it to the shop. This way it takes it all out of my hands, I hope.
I heard from some people that you want to get on it STAT so I did, and took it to the shop immediately. I told them that I knew the spark plug, carb, everything needed to be opened up and flushed out, and they laughed and told me they knew. So, let's hope it's in good hands. It looked so lonly when I had to drop it off. [img]i/expressions/face-icon-small-sad.gif[/img]
Keep your fingers crossed!
Old Sep 16, 2008 | 12:22 AM
JeffinTD's Avatar
Yeah, if there's grit in there, it would be best IMHO to not even turn it over at all...
Old Sep 16, 2008 | 12:28 AM
Do you think that they will check for grit in there before they go and try to turn it over?
Eeek.
Old Sep 16, 2008 | 08:44 AM
action450s's Avatar
Theres lots of topics here on getting your bike running after sinking in clear water, just do a search to see what I've posted 9-10 times now. But like stated earlier if you got muddy water through the engine you need to have it taken apart because the sandy/silt will do a number on the motor. The best case senario would be that it starts burning oil, worst case is a major bearing failure.
You did the right thing taking it to a shop for proper repair.
Old Sep 16, 2008 | 02:32 PM
JeffinTD's Avatar
I don't know what a dealer would do... I'd guess they would drain the crankcase and see what comes out, and proceed from there.
One thing about having the dealer take care of it after being flooded, if it starts to smoke a few hours after you get it back, hopefully they will take care of you.
Customer Service #1
May 15, 2020 08:46 AM
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Jaymc
Sep 11, 2015 07:45 AM
poutlaw525
Sep 9, 2015 03:19 AM
