netural safety switch bypass
Old 10-29-2008, 12:58 AM
wanfernandez's Avatar
Default netural safety switch bypass
does any one know how to bypass the netural safety switch on a 300ex?
Old 10-30-2008, 03:21 PM
Y2daT's Avatar
havent had to do that ...it should start if u pull in the clutch even in gear ....Ill go look at mine and see if i can give you an answer
Old 10-30-2008, 03:42 PM
Y2daT's Avatar
ok I did some testing .......If you go to the left side of your 300 youll find a large rubber boot with a bunch of wires in it ...slide the boot to your left exposing the wire connections ..
look for the connection with a lavender wire and a green wire grouped together(coming from a single black sheething on each side of the connection )
now unplug both connections then take the two conections coming from the front of the 300 and plug them together ....then run a peice of wire so one end connects to the two wires juist plugged togher and the other end needs grounding either to the frame or the negative side of the battery
hope this helps ....
Old 10-30-2008, 03:48 PM
Y2daT's Avatar
if you get it right the nutral light should come on and stay on
my 300ex is a 98 model and wiring has changed a bit over the years ...
if you dont have the same color wires then trace the wire coming from the bottom right hand side of the enjine back to the boot i described eailer and do the same thing
PS i tested this on my 300ex and it worked for me
Old 10-31-2008, 08:07 PM
i will try it tommorow and let you know how it works mine will not start with the clutch in unless it is in netural???????
Old 10-31-2008, 10:45 PM
after you said that it should start in any gear as long as i had the clutch in I checked the wiring around the clutch leaver. The ground wire was cut so i spliced it together and now it works as it should thanks for the info!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-01-2008, 02:13 PM
Y2daT's Avatar
no prob glad i could help
fordfaithful21
12-07-2015 05:52 PM
NRA+1
1) Engine problems..
10
09-20-2015 08:47 PM
nick c
09-13-2015 10:08 AM
Jason An Stacy Jones
Utility ATVs
09-06-2015 02:25 AM
toonces
09-05-2015 01:14 PM
Quick Reply: netural safety switch bypass
