cutting out on a recon
Old Nov 21, 2008 | 04:29 PM
hondarider94's Avatar
Default cutting out on a recon
on my recon..
one time i got done mud bogging and i forgot to put the overflow tube up so it cutout/bogged..
like i can go real slow and not get rpms high and it wont bog but higher rps it cuts out?
next time i did it i pulled it up and it was fine..
came home gave it a nice bath front rack to back rack.. and it would cutout/bog..
<u>BUT</u> BUT if i <u>pull the choke up all the way its fine</u>? as in it will run GREAT
its done this before and cant figure out wat the problem is??
do i need to greese up the wires and stuff or wat?
o and i finally made it across the mud hole that at one point had 1ft deep trenches from a truck
Old Nov 21, 2008 | 09:08 PM
cherokee99's Avatar
sounds kinda like you have a carb problem. mabe an electrical. i would clean out your carb reaal well and make sure you jets are clean. dont forget your pilot jet! its the small brass skrew outside the bowl, twords the engine. remove clean and reinstall. its setting is OUT 2 and 5/8 turns ish.
if your pilot jet is cloged, people use the choke as a make shift pilot. and it will run fine with the choke on, thats what make me think its your pilot.
hope this helps
Old Nov 22, 2008 | 01:05 AM
so should i use some carb cleaner then
Old Nov 22, 2008 | 01:49 AM
cherokee99's Avatar
yes, just a great big can of carb cleaner! if you dont have to dont remove any of the jets inside the bowl, just remove n clean the pilot.
after you hose it down good, look at the holes of the jets and make sure there is no crap in there
good luck!
Old Nov 22, 2008 | 11:12 AM
hey are u on highlifter also??
yeh i did spray it down
Old Nov 22, 2008 | 04:30 PM
cherokee99's Avatar
right now im not on highlifter, im not that big of a mudder...yet[img]i/expressions/beer.gif[/img] but that is a great place to find help as well. anyluck with your problem?
Old Nov 23, 2008 | 11:36 AM
havent tried it yet
Old Nov 23, 2008 | 09:28 PM
BlueRubie's Avatar
Find the fuel filter and replace it. . .
It sounds like a pluged filter as with the choke on your building up some pressure forcing the fuel threw it. . .
Clean the carb and change the fuel filter do the filter first . . .
1. fuel filter test run it.
2. clean out the carb test run it.
post the out come of those 2 thing's. . .
MIKE
Alex G.
Sep 11, 2017 11:38 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Jason Campbell
Sep 7, 2015 02:25 PM
