honda 300ex
Old Dec 10, 2008 | 09:44 PM
  #61
lilc9928's Avatar
Default honda 300ex
excited, parts are scheduled to come in on friday. They were shipped out today and they are ontime.
If it runs after this im gonna have a honda 300ex tribute video of my quad [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 12, 2008 | 07:42 PM
  #62
lilc9928's Avatar
Default honda 300ex
finally put on my wiring harness.
how do you start the atv? do you just have to push the electric start button or what?
like my other atv will only start if the clutch is pulled in.
im clueless at this point....
Old Dec 13, 2008 | 01:00 AM
  #63
lilc9928's Avatar
Default honda 300ex
well just got home, started looking at pictures of the wiring harness and figured out where you plug in the neutral and reverse light. I figured out that the positive and negative are connected together on both neutral and reverse, hopefully this is my problem. If not, I'll go to my honda dealership and buy a repair manual.
Old Dec 13, 2008 | 08:27 AM
  #64
Y2daT's Avatar
Default honda 300ex
(((( to start the 300ex either put it in netural,or pull in the clutch)))
(how to trick the netural light))where the netural reverse light wires connect together on the left side of the machine ....un plug them ,then ground the two wires going away fron the crank case ....turn on the key the nutral light should be on .(even if its in gear).this will enable the start button.
.also there should be two wires that go to your clutch lever perch so you can start it in gear(by pulling in the clutch)some aftermarket clutch lever purches dont have the switch ..in this case hook the two wires together ....and rember to pull in the clutch before trying to start...
Old Dec 13, 2008 | 12:04 PM
  #65
lilc9928's Avatar
Default honda 300ex
I dont have the neutral or reverse light.
What do you mean when you say ground the two wires going away from the crankcase?
Old Dec 13, 2008 | 03:08 PM
  #66
Y2daT's Avatar
Default honda 300ex
there not working? or are they missing?
.my camera is dead so i cant get a pic rnow
but pull your rear fender off...
now on the left side of the quad there is a large rubber boot on the wiring harness
slide it back to expose the wire connections here..
...disconnect the green and purple wires ....
now if you are facing the wires you juist unpluged ,the two going to the left are the two we need ....now plug them together, and connect a spare peice of wire to this connection ...now connect the other end of the spare peice of wire to either the (-)side of the battery or to the frame ..........and try the start button......
Old Dec 13, 2008 | 11:53 PM
  #67
lilc9928's Avatar
Default honda 300ex
my neutral and reverse light is missing.
could you send me pics of what you were talking about with the green and purple wires please?
Old Dec 14, 2008 | 12:32 PM
  #68
lilc9928's Avatar
Default honda 300ex
I made a new thread called Honda 300ex part 2.
Start replying to that one please.
This thread is getting long.
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Wiley wolf
Sep 7, 2015 08:32 PM
Jason Campbell
Sep 7, 2015 02:25 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
