what is wrong???
the battery is probaly weak try jump starting it..or try jumping the cylinoid switch ,,but clicking ussally indicates this works....a dead or dry cell in a battery will give you low voltage lights still work but it wont turn over......if jump starting works ride it and see if the battery takes a charge ...if it dosnt take a charge get a new battery
I had the same problem with my 300ex ,and replaced the battery ..wich fixed my problem( a small lawnmower battery,or motorcycle battery from wallmart is a cheap replacement)im using the( everstart ES12N9-4B-1 )it cost about 24.00 vs the 60.00 honda replacment
