Burning oil?
Old Dec 17, 2008 | 05:05 PM
bigjake34452's Avatar
Default Burning oil?
hello, i have a 03 honda rancher 2wd. i have kept up on the maintenance of the engine but now i seem to be burning oil. it only happens at high rpms, or if im decelerating from a high rpm, its only usually a puff never alot. it just recently started but the way i have had to get the rancher to the riding area is using a trailer too small for 2 atv's. my ranchers front tires sit on a prairies rear rack, total time up about 30 min. would this have anything to do with it?
Old Dec 17, 2008 | 11:26 PM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>it only happens at high rpms, or if im decelerating from a high rpm, its only usually a puff never alot. </end quote></div>
You just described a classic valve guide seal problem.
<div class="FTQUOTE"><begin quote>it just recently started but the way i have had to get the rancher to the riding area is using a trailer too small for 2 atv's. my ranchers front tires sit on a prairies rear rack, total time up about 30 min. would this have anything to do with it? </end quote></div>
It could, but I doubt it. If you get the thing to stand up on it's tail then yes it could depending on the angle of the jug.
I always caution people when they stand their wet sump quad on it's tail to be real careful when they start it. The oil "can" get past the rings and hydro the piston.
Sounds more like a guide seal problem to me.
Old Dec 17, 2008 | 11:42 PM
is there a place to get those seals? i looked in dennis kirk didnt see any.
Old Dec 18, 2008 | 07:14 AM
HondaMechanic's Avatar
I would measure the piston & cylinder also ..
Old Dec 18, 2008 | 09:58 AM
you are thinking there is excessive wear in the cylinder?
Old Dec 18, 2008 | 10:38 AM
GOT BOOST!
<div class="FTQUOTE"><begin quote>you are thinking there is excessive wear in the cylinder? </end quote></div>
Yes; that is what he is thinking.
<div class="FTQUOTE"><begin quote>is there a place to get those seals? i looked in dennis kirk didnt see any. </end quote></div>
The problem is rarey the seal alone. What happpens most of the time is the guide and valve stem wears. When this happens, it wallows the seal out and you start sucking oil.
Usually the guide, seal and valve are junk at this point and all need to be replaced.
Old Dec 18, 2008 | 01:30 PM
well it doesn't do this all the time, is it safe to ride on for a while?
Old Dec 18, 2008 | 11:01 PM
GOT BOOST!
Just keep an eye on your oil level, carry a new plug with you and you will be fine. Go have fun.
Old Dec 19, 2008 | 01:30 AM
cherokee99's Avatar
i agree, you should be fine rideing for a while, but it gets worce doa full overhaul. and for OEM parts, check out bikebandit.com for the valve ,guide, and seals.
Old Dec 19, 2008 | 01:36 PM
i appreciate all the help guys, thanks.
95scramblerruben1033
Sep 23, 2015 06:29 PM
caveeagle
Sep 19, 2015 01:20 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
bvolks
Sep 13, 2015 12:57 PM
Elkaholic
Sep 6, 2015 02:44 PM
