trx450r 05 rear bearing help needed
Old Dec 31, 2008 | 09:31 PM
tntforever1's Avatar
Default trx450r 05 rear bearing help needed
i am trying to change the rear bearings, and having trouble removing the axle nuts. the lock came off no problem . the last nut is my problem. do i turn it the same way as the lock nut to expose the snap ring. Remove the snap ring. then remove both nuts the same rotation? if so what is the trick to get it to move. i have used a pipe wrench with a 6 foot pipe and it will not move. am i going the wrong way? or do a cut it off and buy a new nut
Old Dec 31, 2008 | 09:54 PM
eggenz7's Avatar
i usually cut them off and get new ones. you could try using a heat gun to see if it will break loose.
Old Dec 31, 2008 | 09:59 PM
i hit it with a torch. it did move bu i think i was turning the wrong way. i was spining it up from the rear of the bike. do you know if that is correct?
Old Dec 31, 2008 | 10:01 PM
also how do you cut them off without messing up the threads
Old Jan 1, 2009 | 12:11 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Have you exposed the snap ring? If so you spin it off the same way you spin off the locking nut.
A heat gun my not get the nut hot enough to break down the locktight that is applied at the factory, you may need to use a torch and get the nt nearly red hot.
I was able to remove the nuts on my 450R without heat but I had to cut the locking nut off my 400EX with a cold chisel.
Good luck.
Old Jan 1, 2009 | 03:07 PM
thanks for the help. i got it off and the new bearing are in and runing. gonig rideing thanks again
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
buckshit
Sep 24, 2015 08:49 PM
scaldwellk
Jun 19, 2015 05:08 PM
hoopduerr
Jun 2, 2015 09:01 AM
