Rancher 420 rear seat questions
Old Jan 16, 2009 | 09:03 PM
honda_420_ES's Avatar
Default Rancher 420 rear seat questions
Hey guys,
I bought a new quadrax 2k rear seat for my rancher 420. I paid a little extra and got the heated grips. The seat has two wire harness one for the tail lights and one for the grips. Where do I splice in these wires? I want the lights to come on with brake lights, and the grips to only have power when the key is on. Any help is appreciated. Thanks.
Old Jan 17, 2009 | 10:18 AM
Anybody?
Old Jan 17, 2009 | 04:57 PM
tramp's Avatar
There is a power source plug up by the radiator on the right hand side of the 420. It is up towards the top of the fender attached to the frame. You will need the other end from the Honda dealer to make a factory connection. I have just scotch-locked to the wires. As far as the brake lite, just tap into the wire to the tail light.
Old Jan 17, 2009 | 05:31 PM
<div class="FTQUOTE"><begin quote>Originally posted by: tramp
There is a power source plug up by the radiator on the right hand side of the 420. It is up towards the top of the fender attached to the frame. You will need the other end from the Honda dealer to make a factory connection. I have just scotch-locked to the wires. As far as the brake lite, just tap into the wire to the tail light.</end quote></div>
Thanks for the reply. I got the grips wired up today, just hooked it straight to the battery. Just need to wire up the tail, brake lights. Is there any unused plugs at the rear of the atv?
Old Jan 17, 2009 | 07:32 PM
Amuro's Avatar
if you hooked it up to the battery how will you turn it off??? Or does that seat has a on and off switch???? No the rear has no unused plugs that I know of.
Old Jan 17, 2009 | 07:38 PM
<div class="FTQUOTE"><begin quote>Originally posted by: Amuro
if you hooked it up to the battery how will you turn it off??? Or does that seat has a on and off switch???? No the rear has no unused plugs that I know of.</end quote></div>
Hello,
It came with a Hi/Off/Low switch.
tramp's Avatar
If you are going to use this seat to carry an extra passenger, I would highly sugest you purchase the High-Lifter rear spring to help increase the load carrying cap of the single rear shock.
Old Jan 17, 2009 | 07:41 PM
If you are going to use this seat to carry an extra passenger, I would highly sugest you purchase the High-Lifter rear spring to help increase the load carrying cap of the single rear shock.</end quote></div>
Hello,
Where would I find this spring? I do carry a passenger.
Old Jan 17, 2009 | 08:50 PM
Amuro's Avatar
Click on the link, mine are for sell, It's just me that rides No passenger. It will add more load capacity in front and back.
http://houston.craigslist.org/mcy/993439525.html
Scottma518
Jul 16, 2015 09:19 PM
WilliamBos
Jul 13, 2015 02:11 PM
tricky123
Jul 12, 2015 05:51 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
