No green neutral light and "--- "where the N should be
Old 02-12-2009, 09:21 PM
whitelightnin3006's Avatar
Default No green neutral light and "---
[img][/img][/URL][/IMG]
Old 02-14-2009, 01:04 PM
Gimpster's Avatar
Yes, near where your arrow is pointed in the picture is where the gear position sender is under the engine case.
If the unit is started and a shift system sees a problem, it will shut down the electric shift system until the key is turned off and then back on to reset it. If it sees a problem again, shift system still will not work.
Hope you get it figured out
----- Gimpster -----
Hondamx751
08-13-2015 01:06 AM
ScopeZ_
07-28-2015 01:44 AM
Schneider
07-24-2015 05:05 PM
JoAnnS
07-23-2015 02:18 PM
Derek Allen
07-22-2015 09:25 PM
Quick Reply: No green neutral light and "--- "where the N should be
