2006 Recon choke question.
Old Mar 1, 2009 | 07:25 PM
Dallas700's Avatar
Default 2006 Recon choke question.
I just bought a 2006 Recon for my daughter and it runs like a champ when warmed up but when we first start the quad it will not idle on it's own even with the choke on. The quad is used but in very good shape and I have not cleaned the carb yet just so you know where I'm at. Is this fairly normal because I know there are cold natured but all my other atv's will at least idle with the choke on bt there self.
Old Mar 1, 2009 | 07:54 PM
gambler_m_99's Avatar
They are very cold natured, but should run with the choke on. I would take the carb. off and give it a good cleaning (remove the jets and clean). Also check to make sure that the choke is working. After it gets warmed up put the chock on and see if makes a differance.
Old Mar 2, 2009 | 01:56 AM
JeffinTD's Avatar
Does the choke **** stay all the way out on its own?
Old Mar 2, 2009 | 07:37 AM
pat6366's Avatar
I have a 2007 that I bought new and it is the same way, I need to give it a little throttle for the first 30-45 seconds with the choke out then it will run on its own and I can put the choke in after a couple minutes. I have heard many others say the same thing, so I think you're fine. Its a PITA but once warm they run like a champ.
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
