carb keeps popping on 400ex
Old Mar 5, 2009 | 11:42 PM
jsph_oliver's Avatar
Default carb keeps popping on 400ex
hey new to the site and was wondering why my carb keeps popping on honda 400ex. i have to hold the gas to keep it running and it just continue to pop until it has ran about 20 mins. Any help would be great. thanks joe.
Old Mar 5, 2009 | 11:53 PM
cherokee99's Avatar
you say its "poping" aye? like a hesitation/cough at low throttel or idol? or a backfire?
if its at low throttel you need to bump up your pilot jet, your running a little lean there. pilot jet should be a little brass skrew on the bottom of your carb, turn it OUT 1/4 turn at a time.
had the poping problem on my foreman when i snorkled it, pilot jet adjustment did the trick.
Old Mar 6, 2009 | 12:43 AM
yeah like a hesitation at low throttle won't idle on its own. tried turining the pilot jet but no difference. i was wondering if the jets are bad?
Old Mar 6, 2009 | 12:56 AM
cherokee99's Avatar
i would not think the jrt is bad, but it may need a cleaning. take out the skrew needle, o-rings, and spacer. clean that and the pilot jet hole thoroughly with carb cleaner to remove any gunk. cleaning the rest of the carb would be a good idea as well
have you modded the air box atall? if so you may need to get a larger size pilot jet...i had to step up from a 45 to a 50
Old Mar 6, 2009 | 01:06 AM
cleaned jet but not the whole carb going to try that in the morning. top is off of air box and i'm running a 148 jet. Going to change to 170 or 175 cause i just rebuit the motor to a 426.
Old Mar 6, 2009 | 01:09 AM
oh don't know what size pilot jet i have in haven't got a chance to look at it but the bottom jet is a 148 not sure what they call that one
Old Mar 6, 2009 | 01:27 AM
cherokee99's Avatar
ahh that yould explain your pop. you have alot more air flow now since the lid is off. my guess would be a #40 pilot, mabe a 45 would do you better
Old Mar 6, 2009 | 01:30 AM
thanks for all the info cherokee. i'm going out and get that new pilot jet in the morning and try it out and see what i come up with. will let you know how it turns out. and thanks again man!
Reactant
Mar 30, 2022 02:08 AM
95wolv
Jul 21, 2015 12:25 PM
ghost civic
Jul 19, 2015 10:13 AM
yambam13
Jul 4, 2015 01:49 PM
