Trx 200sx Headlight power question
Old Mar 9, 2009 | 11:15 AM
Fluid72's Avatar
Default Trx 200sx Headlight power question
While riding the light for no reason sometimes gets really bright for a few seconds, then dimms down. Its almost like there is a loose connection or what ever powers them (brushes may be going) or something like that. I'm not really sure how it works. My battery is old and dead so no charge there. Is there anything that can be changed, updated or cleaned?
Thanks
Old Mar 9, 2009 | 11:29 AM
budedm's Avatar
Maybe the hi/low beam switch has a bad connection in it. Take it apart and clean it up.
Old Mar 10, 2009 | 10:40 AM
Fluid72's Avatar
I cleaned all that with no change. i am not sure what generates the power from the motor to the lights.
Old Mar 10, 2009 | 04:16 PM
xbassman's Avatar
If your lights get brighter when you are under power and dimmer with you are not under power, it might be that your rectifier is putting out power when you are on the gas, and less when you are not under a load. Could be??? I do think your battery is a problem!
Cole Hadden
Jun 15, 2025 09:05 AM
Captjay
Jul 23, 2015 12:33 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
tweeder
Jul 5, 2015 01:57 PM
