quick carb question
Old Apr 27, 2009 | 06:16 PM
cherokee99's Avatar
Default quick carb question
i was in the process of rejetting my 300ex carb when i found that my float needle was not letting fuel in when i placed the bowl back on the carb. there is no float adjustmant, and the float itself wound not drop down far enough to allow any fuel in with the bowl on.....what gives? this problem only occurred when i took the carb off to rejet, and did not take the bown off the first time (access plug instead).
when i got further in to the carb the float needle rubber itself was fine, and the passage clear. but when i put the float together and blow threw the fuel hose, the float has to be WAY further down than it can be with the bowl on, in order to pass air/fuel threw it.
im hoping its just the float?
Old Apr 27, 2009 | 08:16 PM
Keeneav's Avatar
Not trying to insult but is it possible you inverted it when you put it back together.
Old Apr 29, 2009 | 10:02 PM
cherokee99's Avatar
its no insult. the float was old and deteriorated. new float fixed it
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
