psi for tires
Old 07-02-2009, 04:14 PM
our250t's Avatar
Default psi for tires
on my 400ex it has 20x11.00-9 maxxis razr tires on rear
fronts are at22x7.00-10 radial h-trak.. is it ok to have the radials on the front and not the rears?? and what psi should i be running front and back??....i looked on the tires and all i see is max psi for seating the beads.... thanks
Old 07-02-2009, 04:43 PM
hoytultratec's Avatar
not sure about yours but on my utilities I run about 5 p.s.i
Old 07-02-2009, 04:54 PM
BEAVER.989's Avatar
4.5-5 front
4-4.5 rear
Old 07-02-2009, 05:52 PM
Scooter86's Avatar
Knows Old ATV Questions!
Originally Posted by BEAVER.989
4.5-5 front
4-4.5 rear
That is usually the range I run as well. Additionally, I wouldn't worry about the radial/non-radial mix on an atv. It isn't like you are going to rotate the tires front to back and have 1 of each on a given axle.
Old 07-02-2009, 06:18 PM
Stoopidbot's Avatar
Depends on the riding. When I'm riding in the mountains(Rocky, muddy, all different terrain) I run 4 all around. When I'm racing the track is hard packed and very fast(about 60mph average speed) I run 7 all around.
Old 07-02-2009, 06:55 PM
Tim Smith's Avatar
On my 300ex at my last race I ran 3.5psi all the way around and didn't have any problem. Mud, rocks, roots, ruts, sidehilling, etc. It was a little wollowy but I am about 190 lbs so some of that is the weight.
On a fast track I run 6psi all-round and it does great. Skates around a little but runs flat to the ground.
Old 07-02-2009, 11:19 PM
our250t's Avatar
i checked them today and they are at 16 psi, maybe thats why it handles like ****, i mean this thing is realy squirrely at higher speeds. another thing i noticed was the front tires are directional and they are faceing the wrong way...thanks for the replys
Old 07-03-2009, 08:25 AM
Stoopidbot's Avatar
Switch your front tires with each other. Put the left onthe right and the right on the left. That will get them spinning in the correct direction. 16 PSI is way to much. That is exactly why it gets squirlly. Try to drop them to about 5psi. That should be a good medium.
Old 07-03-2009, 11:42 PM
our250t's Avatar
droped all psi to 7 and wow night and day, i can now run flat out in 5th, what a rush from riding our 250cc's..thanks
Old 07-04-2009, 08:12 AM
TLC's Avatar
TLC
TLC is offline
The psi is printed on the tires you buy ,it has nothing to do with the ATV you ride.
I hear it all the time " My ATV manual says 5 psi" How does the ATV maker know what kind of tires you will buy down the road? Big difference between 2ply Bais tires vs 6 ply radials.
Quick Reply: psi for tires
