1995 300 ex please help!!!
Old Aug 5, 2009 | 04:53 AM
jjones0315's Avatar
Default 1995 300 ex please help!!!
I just bought a '95 300 ex that has been sitting in a building for about five years. It appears that it is in fair shape. I started it and it won't run under quarter throttle and when it does it is very rough and smokes alot. I have already went through to carb and that helped a very little bit. I also adjusted the valves and that helped a very little bit, but it is still running very bad!!!!!!! Any suggestions would be much appreciated.
Old Aug 5, 2009 | 06:22 AM
gsjeepxr's Avatar
sounds like the pilot jet is still clogged. did you dump the gas out and fill with new high test gasoline? the smoke might get better once you get it running properly and the rings get set and lubed.
Old Aug 5, 2009 | 02:51 PM
jjones0315's Avatar
I did dump the gas and replace it with high test. I will check the pilot again but I am fairly sure that it is clear. Thanks for your quick reply! Any more suggestions would be appreciated.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
bubbagodkin
Jul 12, 2000 01:06 AM
bubbagodkin
Jul 6, 2000 07:46 PM
