Taller Handle Bars
Old Aug 30, 2009 | 08:15 PM
tramp's Avatar
Default Taller Handle Bars
Looking to raise my bar hight on my 420 rancher. I find myself bending over too much when riding and in tight mountain riding I do alot of standing-up. I have adjusted the bars to different position and can't seem to find a comfy spot.
Have thought about a riser block, but would prefer maybe a taller bar. Any suggestion on where I should start looking.
Do the cables on the 420 have enough slack to go 1 or 2" taller?
Thanks
Old Aug 30, 2009 | 09:18 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
While there are a hundred different bends for sport quad/dirt bike bars, I have always found it difficult to find bars for utilities. I would take all the measurements from your stock bars in detatil, then go to some place like RockyMountain and see of I could find a suitable bend.
Old Aug 31, 2009 | 08:39 AM
tramp's Avatar
Thanks Recon
Will check them out. Would the bars from a foreman or rincon be taller? Anybody know.
Thanks
Old Aug 31, 2009 | 11:08 AM
Red Rider
Manufacturers for the most part put cheapie, heavy steel bars on all but the high end MX models. You can give the Foreman and Rincon a try, but I bet they are made of nasty steel.
You might also want to look for some places that sepecialize in aftermarket utility parts. I am usually looking to make my bars lower, so I can get away with a set of sport quad bars.
Old Aug 31, 2009 | 02:04 PM
tramp's Avatar
Decided to go the cheaper route for now and see if there is enough slack in the cables and brake lines to go higher and how much.
Ordered just a 1" plain riser block from Rox Risers. That is what I have on my snowmobile. If that works out to be the hight I need and there is enough slack in all the cables, I will then look at a higher pivot riser or go for a good heavy bar if I can find one. Figured this would be the safe and cheapest mode to go for now. If it doesn't work out, I can always use it on another snowmobile.
Thanks
Old Sep 1, 2009 | 09:31 AM
Tom of Barbaria's Avatar
The wife has an Arctic Cat 366 and it seems to have a really long set of bars they would be ape hangers on a Honda, and i noticed that some Grizzlys have huge bars on them too. I hope that the riser will help you out with what you need
Old Sep 15, 2009 | 04:59 PM
tramp's Avatar
FYI
Put on a 1 1/4 inch riser-block from Rox Risers on my 420 Rancher. That is all the 420 cables will stand. Main problem is the front brake line. However at 1 1/4 inch every thing worked prefect. This made a way better position for standing and now I am not bent over whether standing or sitting.
This is a great addition.
If interested, go to Rox Risers and order the riser-block for the TRX450. Same bolt pattern.
wendal
Sep 7, 2019 06:46 AM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
