04 rancher 350 15a light fuse blows
I have a 04 rancher 350 that when I start the bike it will run for a bit then the 15a light fuse will blow and 4 wheeler will die. The lights aren't turned on and I traced the wires to look for a bare one and didn't find any. I have not really ridden the bike much in the last 5 years because of deployments to Iraq I would say about 50 hours tops. please help me with this headache.
well I just asked my dad what it was doing with him when he rode it while i was gone and he said it was blowing the fuse trying to start. I think it might have died with me after it cranked cause it just hadn't ran in a while. What do I do to fix the problem if it is the wire to the starter or lights?
It has a pull starter....so at least it is rideable (without lights) while you sort out the problem!
Only thing you can do, is trace out the lines and look for a short somewhere. Service manual wiring diagrams and a voltmeter will help.
I had a short once on my 400EX, and it came down to the insulation getting worn off a wire where it got squezed between the plastic and the frame.
jayking232003
07-23-2015 05:48 PM
