What to do with a slow tire leak?
Old Sep 24, 2009 | 07:47 AM
sporter's Avatar
I have 4 good rims with tires I took off a '96 300, $100.00 plus shipping from Arkansas.
Old Sep 24, 2009 | 08:16 AM
When using Slime or Fix a Flat you want to make sure to ride it or get it up on blocks and spin the tires for a few miles worth. It helps to distribute it evenly and gets it out to the rim area.
Old Sep 24, 2009 | 10:46 PM
Sisco1957's Avatar
The spare wheel to a boat I bought was sitting on the ground long enough to sink into the ground. After I mounted the tire it leaked around the rim because the rim was pitted from rust. I cleaned it with a wire brush and put some high temp(red) silicone on the rim. That filled the pits and it held air.
Old Sep 25, 2009 | 08:34 AM
tramp's Avatar
Be careful of what chemicals you use to seal a tire. Alot of chemicals are quite harmful to rubber. Use only chemicals that are designed for use with tires. You can get tire bead sealer at most auto parts stores.
Old Sep 25, 2009 | 03:01 PM
  #15
budedm's Avatar
Default Update
I took the tire off snd the rim looked nice, but the tire had an imperfection on the bead. I dressed it the best I could with a razor and sandpaper. Then I smeared some silicone caulk around it and aired it up. All is well. Thanks for the ideas. Oh - PS - Auto stores have bead sealer but it isn't really what I was looking for. The stuff they have is simply a big bottle of fix-a-flat type sealer.
Ean
Aug 28, 2015 09:39 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
