battery overcharged ?
Old Feb 8, 2010 | 11:19 AM
notmyday's Avatar
Default battery overcharged ?
2005 honda 250 recon. this is my sons machine and the battery is getting overcharged. it keeps losing the acid water in it. it is a maintainence free battery but we took top apart to see what was going on it charges when running at 15.5 volts can anyone tell me what to check as for i dont have a service manuel for this quad. thanks to all.
Old Feb 8, 2010 | 03:41 PM
tramp's Avatar
15.5 is diffently to much......should be around 12.8-13.
Voltage regulator.
Old Feb 8, 2010 | 04:19 PM
notmyday's Avatar
ok ill have him get a new one ty
Old Feb 8, 2010 | 05:21 PM
HondaMechanic's Avatar
Old Feb 8, 2010 | 05:41 PM
notmyday's Avatar
wow 15.5 at 5000 rpm seems high i figured that is what caused the battery to boil all the acid water out. thanks for the diagram. i knew how to check it but didnt have the lights on high beam or at 5000 rpm i raised rpm just a little without the lights on and it was at 15.5 but that was at maybe 800 rom thanks for info guys i love this site.
Old Feb 9, 2010 | 08:10 PM
fritz4001's Avatar
lol wow thats really overcharged, a fully charged 12v battery should be 1.2 volts per cell (12.6v)
Old Feb 9, 2010 | 08:11 PM
fritz4001's Avatar
i meant 2.1 volts per cell not 1.2
Old Feb 9, 2010 | 08:30 PM
budedm's Avatar
Yeah, but that's the voltage taken when the battery is not being charged. The volts going TO the battery as it is being charged is usually more. In this case, 15.5 max. My Recon reads 14.7 when the engine is at 5,000 rpm and the lights are on high beam.
Old Feb 9, 2010 | 09:05 PM
JeffinTD's Avatar
Assuming the battery is an AGM type, there should not be any liquid in the battery. The electrolyte is absorbed in glass matting material, and generally they won’t leak acid even if the case is broken.
Adding water will ruin them, however.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
