Question on gearing down a 450r
Old Apr 20, 2010 | 09:36 PM
Canadian07trx450er's Avatar
Default Question on gearing down a 450r
On my 2007 450r the front sprocket has 15 teeth how much top end in mph will I loose if i come down a tooth. ( A estimate will do) Also will it be good for me to do I want it for dune hill climbing to have a little more power going up.
Old Apr 22, 2010 | 05:32 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You will lose top end but I can't say exactly how much.
I have a 2004 450R and it comes stock with 14/38 gearing.
For trail riding I drop the front to a 13 tooth. For dune riding I drop the front to a 13 and the rear to a 37 tooth.
Old Apr 22, 2010 | 07:27 PM
I checked today and the front had been geared down to a 13 tooth so I'll consider loosing a tooth in the rear. Would you recommend it even if it's a little more expensive than the front?
Old Apr 24, 2010 | 06:19 PM
wildcatkit52's Avatar
Just so you know... DROPPING a tooth in the rear does the OPPOSITE as dropping a tooth in the front. To lower the gear ratio using the rear you want to ADD teeth.
Also the fact that there are a lot of teeth on the rear, one tooth isn't much of a difference in ratio as one added or removed from the front.
So...
Dropping teeth in front lowers the gear ratio.
Adding teeth in the front raises gear ratio.
Dropping teeth in the rear raises the gear ratio.
Adding teeth in the rear lowers the gear ratio.
Old Apr 25, 2010 | 05:50 AM
Pirate Biker
Limping Rider!
Dropping one in the front and one in the rear at the same time lowers the gear ratio from the stock gearing, just not as much as dropping one from the front only.
It is a great combination for the 450R and many of us who own them run that gear ratio, especially in the sand.
Old Apr 26, 2010 | 11:14 PM
AIRMOBILE101's Avatar
06-07 450r's are 13/38 stock gearing. Your run a FCR carb, so just drop it down a tooth (12T) and that should take you were you wanna be.
Old May 2, 2010 | 04:49 PM
In the one catalog they didn't make 12 tooth sprockets but I will look in to finding on.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
ghost civic
Jan 15, 2020 07:43 AM
tporath
Jul 11, 2015 12:31 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
