rear breaks grabbing?
Old Apr 20, 2010 | 09:47 PM
wlvrn's Avatar
Default rear breaks grabbing?
i have a 2005 500 foreman and i think the rear breaks are grabbing. i have taken them apart cleaned them and readjusted them and still they are grabbing. is there something else i can check?
Old Apr 23, 2010 | 02:53 AM
j_lanes44's Avatar
Check the sliders and clips it might need to be changed.
Old Apr 26, 2010 | 02:45 AM
JeffinTD's Avatar
So it grabs hard when applied? Could the shoes be contaminated with something?
Maybe deglazing them with some crocus cloth, followed by another cleaning with a good brake cleaner?
Also, sometimes after cleaning drums, they will be a bit grabby until they bed in.
Old Apr 26, 2010 | 04:44 PM
wlvrn's Avatar
i have done all that and they still feel like they are grabbing. in nutural on a small hill it will not roll on its own. but my polaris rolls and another honda will roll down. when trying to push it on flat concrete its hard to roll, like the break is sticking or something. i wonder if the pumpkin needs taken apart..hmmm
Old Apr 26, 2010 | 05:21 PM
JeffinTD's Avatar
I see, so it is more like they are dragging when not applied, not that they grab hard when you use them?
Warped drum? Anyway, I'd put it up on the jack and see what turns freely and what doesn't.
You could also ride it around without using the brakes and roll up to a stop, and see if the drum is hot.
Old Apr 26, 2010 | 09:46 PM
wlvrn's Avatar
that is correct. more like dragging. ive had it up in the air and they seem somewhat easier but still have a drag. the shoes have less than 100 miles on them so they have seated. it started when water and mud got in the drum. put new shoes and seals in the axle and its been doing it since. about 8 months ago is when that was done and only be riding about 60-70 miles.
Old Apr 27, 2010 | 12:59 AM
JeffinTD's Avatar
I'd guess then that something (a pivot or the cable) is sticking.
Old Apr 27, 2010 | 04:44 PM
wlvrn's Avatar
we just installed a new hand break cable. ill have to check the foot break
Old Apr 28, 2010 | 03:06 AM
sashpa25's Avatar
Rear brakes either way out of adjustment or shoes are soaked with brake fluid from leaking wheel cylinder or gear lube from leaking axle seal.
_____________________
Wine Investment
Fine Wine Investment
Old Apr 28, 2010 | 11:49 AM
wlvrn's Avatar
the drum is dry so ill check the cables and play with them to see if anything helps. thanks guys.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
slowgsxr97
Sep 8, 2015 04:37 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
clsharky
Jul 13, 2015 02:07 PM
