2002 450fe ForemanES shift problems
Old May 19, 2010 | 04:32 AM
ktxl's Avatar
Default 2002 450fe ForemanES shift problems
Hello all, I have a 2002 450fe Foreman and i am having a couple of issues. I have no shift number display on combination meter,nothing,no flashing -- -- ,no N ,1,2,3,4,5 - but the speedo does read except it reads abnormally high !! it says it is going 85 mph in 5th gear. I am thinking the speed sensor is bad but it tests out good.The other problem it has intermittintly,you can shift it up to 5th gear and then it will not downshift,you have to stop machine ,shut it off then restart and it works fine for a few days. Anybody run into these symptoms ?? Any ideas ???
Old Jun 4, 2010 | 08:55 PM
ktxl's Avatar
Default shift problem repaired
Well , I replaced speed sensor and it cured the machine from locking in 5 th gear and replaced the speedometer (combination meter) and that fixed the no shift display problem.
honda71
Jul 12, 2015 05:56 AM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
honda71
Jul 8, 2015 02:13 AM
MNatv89
Jul 7, 2015 11:36 AM
