04 rancher trx350 fm
Old Jun 1, 2010 | 05:48 AM
Badboybob76's Avatar
Default 04 rancher trx350 fm
hello new to atvs, and have a simple question. Honda recently running after 1 to 1 1/2 years sitting, and i have oil blowing in from the breather tube on the air cleaner box in to the air cleaner box. Is this normal and how much is normal if so. I notice the oil is getting into the carb , but I cant see where it is making it run different ? Any experience with this please reply thanks .
Old Jun 1, 2010 | 08:15 AM
JeffinTD's Avatar
No, that wouldn't be normal.
Has the machine been tipped up recently? I'd also wonder about the oil level.
To get an accurate reading on these, it needs to idle for 4 minutes or so, then sit for a few minutes. Set the dipstick on the threads without screwing it in to take a reading.
Old Jun 1, 2010 | 09:20 AM
thanks the unit has 54 hours on it , the only tipping was to get it up ramps in a truck and down the ramps. I had to soak the carb to get it to run. once put back together i started th atv and noticed the oil blowing in the air box. I need to check the oil level then cause it did seem a little high on the dipstick.
Old Jun 1, 2010 | 09:46 AM
TLC's Avatar
TLC
Sounds like to much oil is in the ATV. Drain a little out,better yet do a oil change.
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
blueandy88
Aug 31, 2015 12:42 PM
blueandy88
Aug 30, 2015 08:26 PM
