Impossible bolt? Engine damage if removed? (with pic)
Old Jun 17, 2010 | 07:12 PM
unclejemima's Avatar
Default Impossible bolt? Engine damage if removed? (with pic)
(*****edit***** for some reason it censors out the word "t.o."*****
I have a 2003 250EX (same mo************************************************ ****************r as recon 250)
The Recon has a recoil starter, the 250EX does not. The 250EX has a blank plate where the recoil would go. Inside is a bolt that has ************************************************** ************** be removed in order ************************************************** ************** bolt the recoil basket on.
The bolt I'm trying remove is connected ************************************************** ************** the engine, so when ever I try loosen the bolt, the engine will just turn over.
I've tried putting it in 1st gear and reverse gear ************************************************** ************** lock the mo************************************************ ****************r, but the engine will still spin so the gear has no effect.
Any idea how in heck I would get this bolt off?
Looks like there is a o-ring and another part attached this bolt (#9) (see pic below)
Perhaps I will damage something up by removing the bolt? It might not be as easy as just removing the bolt and re-installing it...? Will it damage the engine or loosen any parts that I can not get access ************************************************** ************** without disassembling the engine? Any idea's?
Thanks
http://s303.pho****************bucke...ent=bolt-1.jpg
Old Jun 17, 2010 | 07:41 PM
zitaron's Avatar
try an air gun
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
