changed clutch side gasket
Old Jul 13, 2010 | 08:52 PM
goldfish26's Avatar
Default changed clutch side gasket
changes cluth side gasket and now it wont stay running. When I pulled off the cover there was what looked like a half inch metal clynder with a rubber o-ring on it. I put it where i thought it went. any ideas?
Old Jul 15, 2010 | 05:43 PM
budedm's Avatar
That sounds like the oil pump tube. Only one spot for it. Near the front in a hole. Shouldn't cause it to not run unless you're saying it runs for like 5 minutes and then dies. If that's the case I guess it could get so hot it shuts down. You could do damage too if you didn't put it in the right spot. It's a hole on the engine side, not the cover you take off, and it's toward the front about 4" up from the bottom of the engine. Been a long time since I had one like yours apart so I could be wrong. Did you ever get a manual? Did you ever get your chain adjusted? Take it slow and do it right and you've got a good quad there.
Old Jul 15, 2010 | 06:01 PM
goldfish26's Avatar
thanks for the info. I just ordered a manual yesterday and still havent got the chain tightened. I dont know if it is just old and stretched or not. Going to wait until I get the book so I can do it right.
Thanks again
ghost civic
Jan 15, 2020 07:43 AM
SDR-II
Sep 29, 2015 01:06 AM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
