Oil Drain Bolt Stripped !
Old Aug 30, 2010 | 01:24 PM
McGuinness's Avatar
Default Oil Drain Bolt Stripped !
All the bolt does is turn and turn inside of my trx 450r.. no oil seems to be leaking but i still need to change the oil eventually and honda said they would need to drill out the screw and put in a timesert but theres a chance metal scrapes might get into the engine or the drill could hit the gears soo possibly an oil siphon pump would do well?
Old Aug 30, 2010 | 03:35 PM
Honda300ex1997's Avatar
Same thin happened to me but I didn't know that when I bought it and mine had just a rubber stopper that worked well
Old Aug 31, 2010 | 07:04 PM
JeffinTD's Avatar
Whatever you do, make sure the plug is good and secure. It would be a bummer to have it dump the oil while you are out riding, and ruin the engine.
There are oversized self-tapping plugs and some other options you might consider.
Old Aug 31, 2010 | 09:17 PM
Hawkman300's Avatar
i just did same thing on my recon and flipped out. but, thanks to autozone, you can buy a replacement oil drain bolt with oversize threads for a couple bucks. works great, just slip it in. watch it though, as you dont want to strip it, but wana make sure its not leaking oil.
and on the plug thing, good idea, but i wouldnt trust my engine to it. those arent designed to withstand heat at ALL, and made of rubber. main reason why i wouldnt.
Old Sep 1, 2010 | 08:48 PM
yeah for some reason this one hasnt melted but i need a new method but that can wait i need things replaced like possibly valves or cam parts when i go to start it no exhaust gases are coming out =/
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 30, 2015 04:27 AM
tysonbully
Sep 28, 2015 02:30 AM
