250x big bore
Old Jan 11, 2021 | 08:35 AM
  #21
Chris250x's Avatar
Originally Posted by trx250xman
Im trying to find out if the big bore kits from the 300ex will fit on a '87 250x? I have heard both yes and no,want to make sure before I buy.. Thanks
It will not work I have a new 330 kit and the jug want go in the bottom end
Old Jun 7, 2023 | 04:28 PM
  #22
Jason81's Avatar
Default Value adjustment
I have a 1992 Honda trx250x i just put a 300 Big bore kit on my question is the value adjustment is it different now with a big bore kit cause i can't get them right it's pushing out of the back of the carb
Old Dec 24, 2023 | 11:18 AM
  #23
Sonnyday's Avatar
Default Big bore kit
I bought a big bore kit for a 250 x and it has a 72 mm piston i had to grind a little bit out of the block to get the cylinder to set all the way down in the block so i don't think a big bore kit will fit without cutting the block to accept the cylinder
Old Dec 24, 2023 | 11:40 AM
  #24
Sonnyday's Avatar
Default Valve lash
no the valve setting is the same. Set your piston to top dead center.use a filler gauge and set clearance to 000.5 intake and exhaust
savage6969
Mar 18, 2009 11:15 PM
REV0351
Sep 4, 2005 05:44 AM
Lomax
Sport Quads
Dec 30, 2004 12:54 PM
whitebroskfx440
11
Aug 23, 2004 05:10 PM
Pit
Mar 8, 2004 09:25 PM
