Please Help!!! Jetting my 250r for the first time!!
I have recently been fouling pugs in my 250r like a **** and I finally found out what jets I should be running. Will stock Honda jets fit in my aftermarket carb? How hard is it to change these jets and are there specific things that I need to watch for like springs flying out when I remove something? I need to get this done soon so that I can get a good feel for the bike for the upcoming season. Thanks in advance
I know this is a pretty old post, but after having a 250R for over 2 years that had to have everything done, I may be of some help.
For a stock Keihin carb 34mm or close to it, 35mm, I suggest starting with 48-50 pilot 150-155 main, needle clip on 2nd or 3rd, air screw 2 turns out. This should put you in the ballpark. Altitude and higher performance parts can make this a challenge. Your local dealership parts guys should let you keep swapping out jets until you get something to work. If nothing works, you may have another problem.
