Motor Oil for 07 Rancher
Your fine with that, the lower the first number(5w) means it good for cold weather cold starts,The second number(30) means how it it works with the motor running hot, the higher the better in that case.
I like 0w-40 because it does it all but I think it only comes in Synthetic. Just make sure its motorcycle grade for wet clutches. Like Amsoil 0w-40. Its not on the chart but you get what I mean if it was there.
N2 has formulated an oil especially for ATV's and their wet clutch applications. You won't find a better oil. Check it out here.
