TRX90EX lights needed
Old May 30, 2012 | 09:48 PM
50ccbeginner's Avatar
Default TRX90EX lights needed
Is there an after-market light kit for a Honda 90 quad or maybe a universal kit? Thanks.
Old May 31, 2012 | 02:15 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Look up "RICKY STATOR" on the internet....they sell a stator coil kit that replaces the stock coil on the TRX90. Quality and fit are spot-on. It will power a 12volt headlight quite well. I bought one for my son's 90 about 8-10 years ago, and it is still working today
Old May 31, 2012 | 07:31 AM
Thanks much. I'll try that! My grandson wants to ride at night. He's been duct taping flashlights to it.
Old Jun 18, 2012 | 11:54 PM
No Ruts, No Glory
Once you get the Ricky Stator system installed, you can put on some lights.
If you look around, you can find HID light conversions that should fit in the light housing, and HIDs are painfully bright Look up HIDNation and it should help out
One other thing to consider as a cool upgrade is to get a kit that will convert the crappy TRX90 brakes and front suspension to accept TRX300EX double a-arms, disc brakes and wheels.
Old Jun 20, 2012 | 04:04 PM
TacticalRedneckofKentucky's Avatar
I've just wired up lights from walmart an auto zone before... works great..
Once i used Strobes from autozone had settings for flash(es) and continuous. each light was about 1.5" tall, 4" long with LEDs in it... Really worked great! I just ran pos & neg wires off wires leading to the headlights on it.... since it has an on off switch you could just stick the wires under the battery terminals Just screw em on!
$20 light job! And strobes!
EDIT... Wait... do 90's have batteries?
Old Jul 2, 2012 | 02:08 AM
No Ruts, No Glory
I have to wonder what you wired them up to, as TRX90's don't have batteries...thus the information about Ricky Stator, etc. These two links should get you started.
Ricky Stator
Ricky Stator
It will also come with info on how to install and how to wire a light system once the stator coil is installed.
Old Jul 2, 2012 | 11:22 AM
i was speaking in general, then i realized the 90's probably don't have batteries... oh well...
jayking232003
Dec 4, 2019 09:38 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
