Smoothened hex nut
Old Feb 19, 2013 | 08:16 PM
Bavander's Avatar
Default Smoothened hex nut
Hi guys,
The previous owner of my 2010 Rancher has smoothened one hex screw used to attach left side engine cover plastic. How to unscrew this hex nut to remove plastic. I tried with liquid wrench to loosen it but hex nut key (Allen key) keeps slipping. Any idea how to remove it.
Old Feb 19, 2013 | 08:50 PM
Ms8091's Avatar
Weld a nut to it and then back it out.
Old Feb 19, 2013 | 08:58 PM
Bavander's Avatar
Great advice thanks a lot. I do not have a welding kit but will try to get one. Any other idea?
Old Feb 19, 2013 | 09:22 PM
Ms8091's Avatar
Drill out the center of the bolt and tap it or drill into it and use an easy out kit. Welding works better.
Old Feb 19, 2013 | 09:31 PM
Scooter86's Avatar
Knows Old ATV Questions!
If you can get a vice grip on the head that may do it. Kind of the same principle as welding a nut onto it. Easy outs can work but I haven't had the best of luck with them. You can also try using a dremel to cut a channel or two and try a large screw driver. Even better if you can pair that with an impact driver. I have also drilled the center of the head off bolts before so the head comes off. Leave as much of the screw as possible so that after removing the rest of the plastic you can get on it with the grips to remove. Spam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word * Warning, I consider that last bit the "nuclear option."
Old Feb 19, 2013 | 09:34 PM
Bavander's Avatar
Thanks Ms8091. I will try it but I think welding should be best option. Do you think I should use superglue to glue a cheap Hex nut key to the nut and try to remove it. I am guessing liquid wrench might have loosend it a bit and glued key may be able to remove it.
Old Feb 19, 2013 | 09:39 PM
Ms8091's Avatar
Super glue will never hold. A 2 part epoxy may work, but if you can't spin it all the way around, you will have a real problem. Harbor Freight and Walmart carry cheap welders that would be good enough, or grab one off of Craigslist. Works every time.
Old Feb 19, 2013 | 09:40 PM
Bavander's Avatar
Thanks Scooter86. I loved your nuclear idea though. lol....
Old Feb 19, 2013 | 09:44 PM
Bavander's Avatar
Ms8091. Thanks very much for great advice. I am off to Walmart super center to get one cheap welders. Will let you guys know of my progress tomorrow.
Jbranum22
Sep 27, 2017 02:05 PM
Phonce
Nov 1, 2009 02:13 PM
DaBeechMan
Dunes and Dune Machines
22
Jul 28, 2003 03:18 AM
MudStud
Jun 9, 2003 10:36 PM
patpath
Nov 19, 2002 01:35 AM
