84 Honda trx200 disconnect ignition switch
Old Mar 14, 2013 | 02:50 PM
Usmcgrl's Avatar
Default 84 Honda trx200 disconnect ignition switch
Ok, so my key is gone, no idea, however my understanding is that i can still start this beast with the pull start by disconnecting the ignition switch.
So what i need is some direction on where to look for the harness. I can see the wires coming out of the key switch running down along the handlebars with about four other wire groups and then they all go into a rubber boot.
I dont see any harness connections under the boot, am i in the right pace and just not digging in enough to this boot (kinda hard to get to) or is there another location i need to look for the harness i need to disconnect?
Old Mar 15, 2013 | 09:09 PM
sprinklz's Avatar
you should be able to just splice a toggle switch into where the ignition switch was
for an '84 i would assume that its a simple keyed switch, two wires, snip snip.
Old Apr 3, 2013 | 08:34 PM
Stapleton1184's Avatar
Two connectors should be black/white wire and a green wire disconnect them that bypasses the ign switch
Old Apr 4, 2013 | 01:06 AM
Ride_TL's Avatar
I was just working on a trx300ex I think 2000 and the 2 ignition wires connected fired it up. Not sure if they create a ground or a power to the cdi.
Old Apr 4, 2013 | 01:16 AM
It will ground it out the little trx 90 my son has I have the ignition wired to a toggle switch and in the off position it will start in the on position it won't and I know I have it Hooked up right
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
cornermike
Jul 8, 2015 11:44 PM
ranvette
Jul 4, 2015 06:13 PM
