short in ignition circuit where to start
Old Oct 2, 2013 | 10:17 AM
  #21
davidh's Avatar
I have spent the past days on the floor, exercising my back muscles so I can again become mobile. going for the front fenders now, anticipate being back on here early afternoon with more information.. slow going for sure.
Old Oct 2, 2013 | 07:24 PM
  #22
papa hogg scoot's Avatar
Loved
Community Favorite
shouldnt have to removed fenders..can get to everything by removing inner fenders...
Old Oct 2, 2013 | 10:17 PM
  #23
davidh's Avatar
got fenders off earlier, I can't bend hardly at all and it has a dealer mounted winch that takes up most of the space under the plastic. however when I disconnected the dash plug, the beep went away. so, tomorrow I will jump each pin to its corresponding socket one at a time and see if anyone causes it to beep again. I suspect I will need to check the diagram and at least hook up a neg to be constantly connected between the plug and socket if it has one, while I do my testing.
my old eyeballs can't see well enuf at night to look at the wiring diagram so it will be a tomorrow job.
am I going in the right direction ?
thanks again. . .
davidh
Old Oct 4, 2013 | 11:52 AM
  #24
davidh's Avatar
back at it again. I did make a jumper wire to connect the two brown wires together. (just like having the plug put together but only the brown wire. . .) then I took another test lead and connected to each post on the "hot side " of the plug, and with a pin connected to the test lead on the other end, I poked it into each of the contacts on the plug that's connected to the meter. all this time I have the beep tester attached to the battery ground and cable ground. no sounds came from that.
next, I attached a jumper from the brown wire that's still hooked onto the two halves of the plug and touched the bl/red stripe on plug and full loud beep came from the tester. looking at the diagram, I see that the bl/red stripe wire goes to the ignition, ok.
where should I go from this point forward ? ? ?
Old Oct 13, 2013 | 04:04 PM
  #25
davidh's Avatar
since I have not seen any replys, I ordered a new dash digital display. both my foreman es have used up the displays so im just hoping that this is my problem. expected by the end of the coming week. I will post a new reply after its here and connected. . . . thanks for reading.
Old Oct 15, 2013 | 04:17 PM
  #26
davidh's Avatar
the new dash arrived today. . I plugged it in and the short is still rearing its ugly head. dammm thing.
where did papa hogg scoot disappear to ? ? ?
tiresharkdbb
Sep 3, 2017 02:06 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
wildbill59
Jun 9, 2015 02:28 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
