86honda3504x4fortrax
Old Dec 19, 2013 | 10:00 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Why was engine rebuilt? broke value? smoke? got stunk in mud and water? wore out? Did run good before rebuilt?
Old Dec 20, 2013 | 06:46 PM
Loved
Community Favorite
Alot of time when an engine breaks an value mean jumpped time ..piston hit value or values causing them to bend..you said nothing about cam chain{timing chain} in the rebuild....Have you rechecked the TDC of engine and camshaft timing? Sometimes jumps time when engine is turned off or engine comes to an sudden stop an the torque of the engine and the slack in cam chain can cause jump time..may have jumpped one tooth an thats why compression is still good but this can cause igniton and compression and fuel to be at the wrong time which could cause NO RUN..Just an ideal..go check Top Dead Center of crankshaft,piston and cam shaft to see if still in time...Thanks and Good Luck
Old Dec 20, 2013 | 07:02 PM
dago82's Avatar
Used timing light hitting on t every. time it is new timing chain its got me flustered. just don't understand but thank u
Old Dec 20, 2013 | 08:27 PM
Loved
Community Favorite
Ok ask again do you have an brand new spark plug in atv engine?
Old Dec 20, 2013 | 08:40 PM
  #15
Loved
Community Favorite
The reason im asking bout spark plug an plug is an part of ignition timing...if you just take the plug out an ground on the block doesnt mean plug is good under an combustion load...plugs can break down while inside of combustion chamber,while an engine is turn over trying to crank, pulling fuel and compression and then,values opens and closes the plug can misfire,,just an ideal and trying to help..Also when using an timing light on these atvs you are just checking ignition to flywhaeel timing not crank and camshaft timing..have to tke cylinder head cover off an TDC camsprocket to align marks to crankshaft to make sure both are dead on.Good Luck
Old Dec 21, 2013 | 04:52 PM
  #16
dago82's Avatar
So itried another new plug today n i thought. for sure it was going to start it was tring real hard n thin rite back to wat it wat doing would not tri to fire no more
Old Dec 21, 2013 | 06:04 PM
  #17
Loved
Community Favorite
Does the engine sounds like its hitting any at all?
Old Dec 22, 2013 | 12:08 AM
  #18
2003wolverine350's Avatar
Wow got me puzzled! Maybe spark plug wire or maybe there is a fuel problem some where. Maybe the starter went bad? Or stator??
Old Dec 22, 2013 | 03:13 AM
  #19
In all this thread there is no mention of you cleaning the carb out. If you put in a nice dry plug and it tried to start, it sounds a lot like too much fuel getting into the cylinder, this would explain why starting fluid didn’t work. A loose jet, stuck CD piston or choke device can all cause an excessively rich mixture. Another possibility is the coil or lead not giving enough power to fire the mixture, it may try, but soon “wets” the plug and gives up.
