Foreman 400 - Wouldn't start without Neutral light
Old Sep 15, 1999 | 12:55 PM
PinkFloyd's Avatar
I know the Foreman needs to be in Neutral to start, but I didn't know the little green light had to actually be on . . . Found that out a few days ago.
Under the right rear fender there are a few sets of wires. Two of them in one harness are for the reverse (i think) and the neutral light. A stick must've snagged the neutral wire and pulled it out because when I shut the machine off and tried to start it again, it wouldn't turn over. The bike WAS in neutral but the light wasn't on. After searching for 10 minutes I found this loose wire, made contact with it's connecting wire and I was on my way . . . Just thought someone may want to know.
P.S. The pull start doesn't work either if the neutral light is not on . . .
Old Sep 17, 1999 | 09:51 AM
sibbs's Avatar
That makes sense. This is the same wire that you would wire a grounded switch to if you wanted to add a start-in-gear switch. Was it the green wire with a red stripe?
Old Sep 17, 1999 | 12:54 PM
Foreman4x4's Avatar
Where can I get a start in gear kit ? And how difficult would it be to install ? That's one thing I dislike about my Foreman is the fact it has to be in neutral to start . I was hoping there was something that could just be disconnected . Thanks for any info .
neilbedwell
Nov 10, 2018 11:02 AM
Dabears1983
Jun 16, 2015 12:17 PM
jayking232003
Jun 9, 2015 02:54 PM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
