Honda Recon loose differential cables
They are the breathers for the rear brake and diff, and must run high enough up to be above water level when you go through deep water, they also need to end somewhere where rain water isn't going to get into them either. If I remember rightly Honda end them pointing downwards through a bracket moulded into the snorkel tube or tank.
