Bob /Karen Wines
Old May 30, 2017 | 10:34 PM
bob/karenwines's Avatar
Default Bob /Karen Wines
It's noisy when it shifts, a clattering noise. It doesn't happen all the time. Trying to prevent a bigger problem.
Old May 31, 2017 | 01:41 AM
Knowing which model would be a start. However assuming a manual or ES gearbox, the fault may be clutch adjustment. Try that first.
"The machine has two clutches, a centrifugal one for setting off in first or reverse, and a conventional motorcycle multiplate clutch. The conventional one is operated by the gearchange pedal, as you start to move it, the clutch disengages, then it gets far enough to change gear. As you lift your foot off, the clutch re-engages. On an ES all this is done by the electric motor. An adjuster is on the clutch cover, slacken the locknut, turn the adjuster anti-clockwise until "resistance is felt" then back off 1/4 turn. Tighten the locknut."
Old May 31, 2017 | 08:43 AM
LT80's Avatar
LT80 Expert
Trx90?............lmao
Old Jun 1, 2017 | 12:25 PM
Ajax's Avatar
Nope.. from the precise description id say a..
Tanfordtruckin
Apr 12, 2017 06:50 PM
Wizzlenuts
Dec 5, 2014 12:04 AM
loadan5055
May 13, 2011 07:16 PM
hotdog
Jun 20, 2002 04:01 AM
