400EX jetting help..
Old 02-28-2019, 07:48 PM
sr.ruedas's Avatar
Anything under 40 for the pilot jet is quite small and prone to clogging in my experience. The Chinese units copy the jets well, but save some money by leaving them unmarked. !
Old 03-01-2019, 09:16 PM
Parks1181's Avatar
Originally Posted by Lt Granddad
There was a pipe shoot out Dirt Wheels March 2001that had the main at 160 for the ct pipe but also came with their needle and different pilot which they didn’t disclose. I’ve seen a lot of people suggesting a 42 pilot which was eliminating the need for a choke to start the bike but I’ve seen as low as 3/4 turn out to 2 3/4 turns out on the fuel mixture.screw using the 42 pilot. Being an 04 you should have adjustable needle would try lowering 1 notch like sr.ruedas suggested 2nd from bottom.
gonna need all the help I can get lol, so I took apart the carb the other night and moved it to the 4th clip on the needle, and also I installed a 162 main and 40 pilot. I struggled but I managed to get it running for a few minutes and it sounded good revving it, not perfect but ok, it wouldn’t stay idling. But I went to adjust the air mixture screw, and it was turned all the way in? So I tried to back it out just one turn and now there’s gas leaking from the carburetor out of the overflow tube. Kinda lost.. help would be greatly appreciated guys! Thanks a lot
wsy480
07-20-2009 08:09 AM
chuck400ex
06-01-2000 08:15 PM
wcy2k400ex
04-28-2000 01:17 AM
Bruce
11-30-1999 05:07 PM
Quick Reply: 400EX jetting help..
