Starter gear problems
Old Mar 25, 2019 | 05:56 PM
Kylec's Avatar
Default Starter gear problems
Hello.. I have a honda 350 fourtrax 1986 that has problems with something inside the motor not grabbing to start the bike. I have peeled apart where the starter is and all of the gears are good that i can see, i would like some answers if anyone could help, thanks
Old Mar 26, 2019 | 03:23 AM
Those gears turn a one way clutch behind the flywheel. If the gears are OK the one way clutch must be slipping. Not a lot you can do with the ones on 300s and I guess the 350D will be the same. Remove the flywheel take the clutch off it, and replace with a new clutch.
OuterLimit
Oct 3, 2004 01:20 PM
firebry32
Aug 31, 2004 10:40 PM
BlackHawk
Feb 8, 2004 11:53 AM
dszydel
Jun 7, 2003 03:35 AM
