2006 honda rancher 4x4 400 at
Old 06-25-2019, 02:59 AM
Brian Ballard's Avatar
Default 2006 honda rancher 4x4 400 at
Okay my rancher want show any gear on display just flashes 6 times esp also it want change out of first gear. None of the es up and down want work and it jumps when u give it gas in reverse... Will someone please help me through this please... If i have to bypass or rig something to change gears i will thanks...
Old 06-26-2019, 01:54 AM
Just checked on-line and code 6 is angle sensor faulty. If I remember correctly these are expensive, and tricky to fit as they need pre-loading on the 400AT, so watch what happens when you take the screws out that hold the old one in. I'm fairly sure it springs through about 1/3 of a turn, note which direction, the new one needs to go in at the same angle and is then turned back in the opposite direction, so the screws can be fitted.
Ozark??..
Utility ATVs
11
11-07-2008 01:55 AM
Quick Reply: 2006 honda rancher 4x4 400 at
