Superwinch Rocker Switch
Old May 2, 2001 | 02:47 PM
Mork's Avatar
Looking for a reliable replacement to the stock rocker switch that comes with the Superwinch I have. Any such thing available??? Think they would make a decent, durable switch for these things!
Old May 2, 2001 | 08:04 PM
loosenutz's Avatar
Here's the work around i used. went to the local electronics store and picked up a toggle style switch instead of the button. Works the same way, just looks different. It automatically flips to the off position like the orginal too. The problem here is the switch would only handle a 20amp load wich is not eneough for the winch so i also bought a 40 amp relay to wire inline with the switch. It handles the load and the switch just does the switching. $13 dollars well spent. the big plus is this setup is much smaller than that huge rocker switch. Any questions just let me know.
Old May 3, 2001 | 05:14 PM
4x4king's Avatar
i stopped at my Honda dealer and bought a Warn switch for $50. But then my stupid friend broke it, so it was a waste of money. Other than that they are great switches.
Old May 3, 2001 | 06:04 PM
Joe4x4Foreman's Avatar
I burned up two of those switches. My solution was to use the rotary switch available for the Superwinch. It's not as neat and compact as the rocker so I mounted it on the back of the front rack where I could easily reach it to lift/lower my plow. No problems with with it at all. By the way, all Superwinch switches shunt (short) the motor in the OFF position. This provides dynamic braking for the winch. Without dynamic braking the winch will creep under load. This fact may or may not be of importance in your application.
Old May 4, 2001 | 01:53 PM
Mork's Avatar
Thanks for the replys guys! I am aware of the dynamic braking on the Superwinch. Does the Warn switch short in the off position also????
Old May 4, 2001 | 06:03 PM
Ursus's Avatar
Was 40 amp the biggest relay you could find? According to the winch manual it can draw over 90 amps at a full load. I am curious as to how you wired it all together. Did you use a single pole or double pole momentary on switch? I can't figure out how you did it with only one relay(unless it was a double pole double throw relay which I didn't know they made).
I too am very fed up with the rocker switch, it gets dirty too easy. The relay idea sounds good though.
Old May 5, 2001 | 12:12 AM
polardogg's Avatar
The first switch that came with my superwinch had no rubber boot to protect the insides. After that switch died I e-mailed them, they sent me a new switch with the boot it's been fine after that. Did yours have the boot?
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nick c
Sep 13, 2015 10:08 AM
alzgarvin
Sep 11, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
toonces
Sep 5, 2015 01:14 PM
