o-ring,x-ring or no ring that is the ?
Old May 18, 2001 | 10:12 PM
ugly's Avatar
I am ordering new chain and sprockets tommorow.I am going to order from rocky mountain atv.I am going to get sunstar front and rear sprockets but I am not sure on what type of chain.This will be on a 250r that is ridden only ridin on mx tracks and sand/chat.
I heard that sand eats the o-rings up ruining your chian so get a standard.But also I want to get the most hp to the ground with the o-ring chain.I am not to familar with the x-ring design.
Please have any answers by tommorow!
Old May 18, 2001 | 11:50 PM
Zorro's Avatar
I'm not familiar with the X-ring chain either
if you want the lightest and most "powerful" (actually the least power robbing) chain, then get a no ring chain. But my guess is that it will wear MUCH faster than an Oring chain (and yes, I too have heard that sand eats the Orings). But it's lighter, probably cheaper. It needs more maintenance too(you can't miss a cleaning/lubing).
Old May 18, 2001 | 11:52 PM
luckywilson's Avatar
I have a 87R do not use a standard chain.The bike will kill it in just one day.Before you get the chain ask the person what the wearlife rating is what is the tensile in lbs.perfoot, are the bushings solid or curled.Try to get a tensile around 7500lb. to 8000 lb. wear life 500 to 600. If they do not know do not fool with it. O ring chains are good. The X rings are a bit better. The RK X ring chain with a JT front and rear should be about $105.00 for quads and $115.00 for bikes.
Old May 19, 2001 | 01:25 PM
ugly's Avatar
Well I went to the honda shop and bought a new chain and front sprocket I also get a new honda clutch cable and cable adjuster for the clutch perch.It was 88 dollars.(which happens to be how much I had)
I got a d.i.d standard chain and a honda 13 tooth sprocket.All the honda shop had was 37 tooth rear.I am getting gready to go get a JT pro series steel 39 tooth rear.From somewhere else.It is 27 bucks.I got a 100 link chain and master link.I also got some free stickers.
86 trx250r wiseco .020 piston,boyesen reeds,fmf gold series fatty pipe,power core 2 silencer,Dg alloy series nerfs,jd performance +2 A-arms,durablue eliminator 2+2 adjustable width axle,durablue posi loc axle nut,white bro's white power shocks with adjustable res's all the way around,Ac stadium series front bumper,renthal trx250r bend handlebars,909 grips,uni filter,nac's casesaver,fastline braided steel brake lines,PEP easy pull clutch perch and lever,d.i.d chain,JT pro series rear sprocket,braking brake pads,18/11/8 holeshot mx's on mitchell .190's,21/7/10 ,holeshots on ITP .190's
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
