Clutch lever for 300ex
Old Jul 8, 2001 | 10:44 AM
Zoinks!!!'s Avatar
On the fourth of July I rolled my 300ex(long story) and the clutch lever broke. Last year the bolt that helps tighten up the parking brake broke so I removed it completely so the parking brake set up is still on the clutch lever. I need to know where I can find a new clutch lever that gets rid of the parking brake crap but still keeps the reverse **** for reverse. Can you guys help me out its actually my wifes quad and she cant ride it till I get a new lever!
Thanks
Old Jul 8, 2001 | 10:57 AM
moto93's Avatar
I don't think there's an aftermarket clutch lever set-up out there that retains the reverse button. I just removed the parking brake thing and made a little spacer to put where it went. Worked for me!
Old Jul 8, 2001 | 11:00 AM
Zoinks!!!'s Avatar
So how do you use reverse or is it you just dont?
Thanks for the reply!
Old Jul 8, 2001 | 01:15 PM
kkkiller300ex's Avatar
my freind had the some problume he put the revers on the bars and got a two figerd clutch lever it works way beter then the longer lever. good luck!!!!!!
Old Jul 9, 2001 | 10:53 AM
moto93's Avatar
You still use the stock set-up just remove the parking brake thing and make a little spacer to put where it went.
Old Jul 9, 2001 | 11:23 PM
Zoinks!!!'s Avatar
I have to buy a new clutch lever cause it broke in the rollover thats why I am asking if there is a clutch lever for the 300 ex that has the reverse **** on the lever.
Old Jul 10, 2001 | 08:10 PM
94DGblaster's Avatar
you don't need the reverse lever to use reverse
just buy a whole new clutch lever, take off the reverse cable, and go down on the side of the motor and tie back the lever so reverse can be used. It won't go in reverse when its in gear..so you can't hurt anything, ie accidently kick it in, its impossible
Old Jul 10, 2001 | 09:55 PM
BigDogX's Avatar
Here's a suggestion. IF and only IF a stock lever is within your budget, buy it. I dont know and havent looked into a aftermarket clutch lever for a 300EX, they have to be out there though. if you get the stock lever and want to get rid of the parking brake stuff, here is what i did, i took off the parking brake cable and linkage and threw it... then took that little piece on the lever that the parking brake worked off of and cut it with a chop saw... works like a charm, beautifully planned idea.... any ?'s ask.
jbrewster94
Sep 23, 2015 04:16 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
