400ex axle locknut removal "HELP"
Old Jul 21, 2001 | 01:35 PM
nicca's Avatar
I turned the inner axle locknut clockwise, But it doesn't seem to loosen all the way. It begins to losen, but then tightens again. I also turned the outer nut counterclockwise once the inner one "seemed to be lose" ,and the snap-ring will not come out.
can someone give me a clue here.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jul 21, 2001 | 06:56 PM
derekhonda's Avatar
That clip sure is a b!tch, the way i did it was stick two small flathead screwdrivers in there and try and spread it apart. It was really tough though, but just keep trying. Why are you trying to get it off, or are you just trying to tighten it up?
Derek
Old Jul 21, 2001 | 07:53 PM
springdrl's Avatar
It sounds as if you guys should invest in a good pair of c-clip pliars made especially for such use. Make sure you get the type which spread c-clips open as oppposed to the other type which compress them so that they can be removed from a inner race.
It sounds like this definitely a case where the right tool for the job can make all the difference. That is unless you have plenty of time and a deep vocabulary of four-letter words.
Old Jul 21, 2001 | 10:24 PM
nicca's Avatar
I am in the process of replacing the axle bearings and seals..
i was able to get everything off... my book gave me incorrect directions... "300ex and 400ex"
well... in the process i mauled the axle locknut.. how much does one of those cost??
I also need a new o-ring and "spring" set for the axle carrier..
does anyone knowhow much these will cost?
Old Jul 21, 2001 | 11:30 PM
KKKILLER250X's Avatar
i just replaced all the things you are talking about + the disc brake hub and it cvost me close to $350 i suspect you can get it done for about $260 , i bought a lonestar twin row bearing carrier so the bearings last longer , I recomend the same for you . Good luck
Old Jul 21, 2001 | 11:42 PM
springdrl's Avatar
Bearings and c-clips are manufactured in standard sizes and available from a number of sources including your local auto parts store.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Cantbuytime
Aug 16, 2015 09:13 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
