Top end rebuild oil in the crankcase
Old Aug 4, 2001 | 11:36 PM
greenn50's Avatar
Today I took the jug and piston off my 250r. I noticed that there seamed to be a-lot of oil around the counter balance throws of the crank and on the bottom skirt of the piston. My question is, is it normal for the crankcase to receive that much oil from just the mixed fuel or maybe I have a leak from the trans. in to the crankcase. I should have done a vacuum test before tare down but now it all apart and I don’t want to spend the time to put it back together to find out it does have a leak. Thanks for the help!
Old Aug 5, 2001 | 12:38 AM
Elrancho's Avatar
If you had a leak large enough to care about it'd render a two stroke unrunnable from fouled plugs in short order. Does your plug look like a normal two stroker plug, or is it building up oily ash. Basicly if you're not building up gunk on the piston top and your plugs are fine-foggetaboutit.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
