Put a grease fitting in my rear axle housing(200SX)
I saw a thread saying its good to have a grease fitting in your rear axle so you can grease your bearings, its a benifit so you dont have to tear the rear end apart all the time.
All I did was take the rear end apart, then drill a hole for the fitting(right near the brake) then screw it in, then cleaned the housing out so no metal shavings are in there to mess up the bearings, then put everything back together and then greased it up!
Its very easy to do.
