ping problem
Old Oct 24, 1999 | 01:17 PM
bigmanMH's Avatar
i have a wiseco 10:1 compression piston and i have 93 octane premium gas with octane booster that boost up to 4 to 7 points. It pings when i give it a lot of gas trying to accelerate and when i put it in 5th gear.
Right when i get it out when it is cold it won't ping till it gets warm about 2 minutes later. know what to do.
Old Oct 24, 1999 | 03:31 PM
Tree Farmer's Avatar
You can boost your octane with fuel additives or use some high-test racing fuel.
Retarding the spark slightly may help (although some potential performance may be lost).
You could lower the compression ratio slightly perhaps by adding an extra headgasket or shim; however, you'd sacrifice some high-compression power advantage there.
I think pinging after warm-up may indicate thermal expansion of piston, rings, etc., to give a good seal.
Good luck.
Tree Farmer
Old Oct 24, 1999 | 03:52 PM
JRM's Avatar
JRM
That isnt cool, I once rebuilt a XR200 with a 10:1 pistion..it had a funkey pistion slap knock that sounded kinda like pinging when under heavy throttle..If yours is truley pinging id frist try going one step richer on the main jet and lower the clip on the needle one notch..lean jetting would cause hot pinging. if that doesnt work, try the other stuff on the post before mine, as those are the only other things to do. Joe
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
