Rear Raptor shock on 300ex
Old Dec 30, 2001 | 06:27 PM
hyper660r's Avatar
I was extending a guys 300ex swingarm last week and I sat his shock down next to some raptor shocks I was rebuilding and putting the zero preload kits on them.I notice they were the same length.I put one of the raptor rear shocks on the 300ex and it works great.More travel,compression & rebound adjustment,its like installing a after market shock.So if you guys are looking for a better rear shock a cheap way is to find a used Raptor shock,sometimes there on ebay. [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 31, 2005 | 08:22 PM
joe4g63's Avatar
Default Rear Raptor shock on 300ex
yeah man just wondering what year raptor did that shock come off of?
Old May 31, 2005 | 11:50 PM
1988fast250x's Avatar
ya what year raptor and its the stock shock right not the one for the longer swing arm!
THANKS
Old Jun 1, 2005 | 08:54 AM
95wolv's Avatar
It has to be a 2001 Raptor, the only year with a remote resivoir, the newer ones with a piggy back will not fit. I have a 2001 shock on my son's 300ex, and ended up getting a longer hose for the rez to mount it out of the way, the stock one is a bit short.
Old Jun 8, 2005 | 01:44 PM
CoyoteRiverRaptor's Avatar
95, how long did you go (total length) on that res line? Then where did you mount it?
Thank you in adavance.
Old Jun 8, 2005 | 03:24 PM
95wolv's Avatar
CRR,
The shock I picked up needed a rebuild,I lived only a few miles from Rath Racing, so I had him take care of it, he took the stock banjo type fitting and rethreaded it for a straight in fitting with a steel braided line, 10" long. It mounted up fine, but the best spot I could find was on the frame under the seat, but my son managed to come down hard enough from a jump to catch the hose with the chain (what was I thinking, mounting it above the chain !!) and ripped it and the rez loose. I was able to weld up the gash in the rez, and haven't remounted the shock yet, but I will have to look real hard at a new mounting spot, and will probably need a bit longer hose. I will get this done, and post the results.
Old Jun 8, 2005 | 08:11 PM
95, thanks for the heads up information. I know you have saved me some time and grief.
crr
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Asaran
Oct 8, 2015 11:14 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
07Redrider400
Jul 25, 2015 05:31 PM
